Cloud Setup Will not work with open WiFi - Blackvue please fix
MarcWinNJ
New Jersey
I have the 650 2 channel. I love the camera. I have tried to set up the cloud connectivity on Optimum WiFi in the NY/NJ area. Optimum and the other cable companies use an open access method. Once you connect to the SSID it does one of two things 1) on a mobile device it brings up a user name and password for authentication. and 2) you can register your MAC address and the device will connect and authenticate automatically.
I am using option 2. The problem is when you go into Cloud setup it scans, see the "optimumwifi" SSID. Click it and it wants a passcode. The firmware will not allow you to save the settings without a passcode thereby making the cloud feature not useable.
I hope that Blackvue and Pittasoft check these boards and they can can you change the firmware on the cloud settings to allow just an SSID and no passcode.
Thx
MarcWinNJ
MarcWinNJ
New Jersey
45 views but no replies or comments. Anyone have any ideas on how to get this working
Ralph2
Edmonton AB
BlackVue 650GW in 2011 Highlander
The "cloud" in development and there are few folk that have figured out how to manipulate it to something useful. Official response will not likely to ever happen here.. your best (only) hope is to correspond with Pittasoft..
infinkc
You might need like a mini wireless router also in the car, most of them you setup with a computer to clone the MAC address of the computer. Once the MAC address is cloned the router becomes the "computer" and has it own ssid that you setup to broadcast the signal back out with your own info. This will also you to connect to the router with normal settings.
People use these to join say the wifi on a plane to share it out to many devices instead of paying the fee for each.
there is probably a program that will let you spoof the MAC address of the camera on the computer and then setup your connection that way. Once setup your MAC address for the cam should be on the network.
MarcWinNJ
MarcWinNJ
New Jersey
Thx
I got this from Blackvue and will try this:
Dear Customer, Thank you for choosing BlackVue. To configure Cloud hotspot settings without the WiFi access point's password ,unplug the power cable of the dashcam and take out the SD card->Connect in to your PC->Open the BlackVue PC/MAC Viewer program-> go to "Settings"/ "Preferences" -> Cloud settings-> input the SSID of the Wi-Fi hotspot -> Save&Close. Insert the SD card in the dashcam and power it up. Hope it will solve the issue.
drewtzn
hey MarcWinNJ, I'm having the same issue!
I have the 650S with v.1.007 firmware.
I am able to save "optimumwifi" as the SSID and leaving the password field empty. I have entered/registered the MAC address to my optimum account.
However, it doesn't seem to be connecting or having trouble connecting to all optimumwifi.
The dashcam always says "wireless hotspot unavailable" and "wireless access point device limit reached" while I was driving.
drewtzn
reply from BlackVue support:
"However, Blackvue cloud service can only connect to protected wi-fi internet.
Which means “optimumwifi” is not possible since its has no password. That might be the issue why
your dashcam can not connect to it. "
seems like the dashcam doesn't support open networks.
they should include it doesn't support open networks on their website and on sellers' websites.
I mainly bought the 650S-2CH because I thought it will connect to optimumwifi in my area, but it doesn't support open networks. this makes a huge difference! bummer
I have asked them to add support for open networks.
