Collision not an event???
Rikske
Brussels
Belgium
Hello,
I just did some test for the problem I had with my previous post --> https://dashcamtalk.com/forum/threads/location-event-files.39899/
It seems that a collision is not marked as an event, when I check the notifications the application told me their was a collision but it wasn't marked as an event so it was overwritten by a newer file.
I shaked the car as a test and then the application recorded that as an event file?
I think it's quite obvious that a collision should always be marked as an event or am I doing something wrong :unsure::unsure::unsure:
Thank you for the advice.
KR
Eric
M8TJT
Bexhill, East Sussex
Not relevant to events, but I hope your car was not damaged a lot during this episode.
R
Rikske
Brussels
Belgium
Is there a way to block these files on the card so that they aren't overwritten?
And I think we were hit with a ladder on a trailer because we have 2 dents in the trunk :mad:
dbareis
Australia / Victoria
BlackVue DR900S-2CH
I assume you would need to adjust the sensitivity
Sent from my SM-T590 using Tapatalk
R
Rikske
Brussels
Belgium
I don't understand what you mean, it's set to level 9 in parking mode so that is not the problem, it was registred but not saved as an event.
dbareis
BlackVue DR900S-2CH
What do you mean by registered? I don't know if 9 is sensitive or insensitive.
M8TJT
@dbareis 9 is maximum sensitivity (I thought it was 8).
@Rikske What do you mean by 'registered'.
If you 'shook the car' and the camera recorded an event file, then it appears that it is doing what it is supposed to.
What application? Do you mean the camera or something else?
What do you mean by registered? On what? (Or am I being incredibly stupid?)
There should be no difference between a 'shake' and a 'collision' as it will be the G sensor that detects either.
Your problem being spread between two threads isn't helping either.
R
Rikske
Brussels
Belgium
What I mean for registred is that I can see it on the Blackvue app on my phone under Cloud -- Notifications : "Collission detected in parking mode" with the timestamp.
The sensitivity goes to 10 and that is then the most sensitive.
R
Rikske
Brussels
Belgium
What application? Do you mean the camera or something else?What do you mean by registered? On what? (Or am I being incredibly stupid?)
What I mean for registred is that I can see it on the Blackvue App on my phone under Cloud -- Notifications, their it says "collision detected in parking mode" with a timestamp.
The problem is that this event (collission) was correctly recorded on my card but for one reason this kind of impacts aren't marked as event so it was overwritten by newer files on my memory "card".
And like you said if I shake my car this is registred and recorded on my card and also marked as an event but a collision isn't, I find this verry strange?
M8TJT
Thanks for the clarification.
Very strange indeed as both would have been triggered by the G sensor. Is the 'shake my car' notified as a 'collision' on the BV app the same as the actual bump was?
R
Rikske
Brussels
Belgium
Yes idd it was also marked as a collission, I will try to replicate it this weekend because I formated my memory card to be sure that the problem wasn't situated at that level.
I'll keep u posted :)
