petesamprs
- Jan 16, 2016
- Afghanistan
Hi,
I'm looking to purchase a Mobius and hardwire it into my car. Was going to get the capacitor version with a C2 wideangle lens. Car is a BMW F10 5 series in the US.
Already have a Valentine 1 hardwired, with an RJ11 (telephone) cable running along the headliner, down the passenger A pillar and into the fuse box behind the glove box. Tapped into a fuse that is powered only when the car is on, using an Add-a-Fuse.
My goal is a for a very stealth mobius install, so i'm thinking of actually attaching the camera it to the underside of, or adjacent to, the V1 (via hot glue or strong velcro) rather than having its own mount. I'm hoping heat shouldn't be an issue as long as the heatsink is exposed.
Some questions:
- Is there any way the mobius can tap the power provided by the existing RJ11 cable for the V1, or do I need to run a dedicated power source along the same path to the fusebox? The V1's power requirements are as follows:
"Power Requirements: 11.0-16.0 Volts DC negative ground. 225 mA typical standby, 425 mA maximum alarm condition"
- If I have to run a dedicated power source for the Mobius to my fuse box, what additional parts do I need to get the mobius's USB wire to connect to my fusebox?
- Can my V1 and Mobius tap the same fuse? If so, how?
thanks.
Some questions:
thanks.
