Compatible SD cards??
rockyrr
Maryland
DR500GW-HD
I want to buy a micro 32GB SD card for my DR500GW-HD dash cam. Exactly what type of SD card should I be looking for that works with my cam, and where is a good place to buy one?
I ask this because I've found that there are differences and not all will function properly with all devices (photo cams, video cams, etc.).
Thanks,
Rocky
linni
Estonia
Class 10 would be fine.
Running also Sandisc Ultra 32GB and switching to Ultra 64GB soon.
Dscheng
Singapore
Blackvue DR500 with Custom firmware / Stamp
I dont think BV can support up to 64GB. According from the user manual, it show max 32GB. Please correct me if i am wrong :D
BTW, i am using samsung class 10 32GB. So far so good, but when i take out the card from my BV, it is very hot. I am wondering how long can the card last?
horsepower
Thinkware F800
Memory cards are deemed consumable items. I would expect to get a year out of them. But you may have some for years and have no problems. I just wouldn't be too shocked if one went bad and you had to replace.
linni
Estonia
jokiin said:
are SDXC cards supported?
By default, SDXC cards are not supported. Blackvue recognizes FAT filesystem but not exFAT, the SDXC cards use.
So you need to reformat memory card. Microsoft is sure, that this kind of action is impossible. But it`s not.
All you need is a simple program like this:
http://www.softpedia.com/get/System/Har ... Tool.shtml
Just do not forget to set the cluster size to 32kb.
R
rockyrr
Maryland
DR500GW-HD
Hey, folks, thanks for all the helpful feedback. I was surprised to learn that SD cards are considered "consumables".
TCB
Toronto
Silly question:
I have the new DR500 Blackvue with 16GB factory micro card.
If I will replace it with 32 GB and format it inside the camera will I have to download card content? If yes where I can download? Mine is english version.
thanks
Dscheng
Singapore
Simple, just plug in your new microSD into your cam. Press and hold on WIFI button for 10 sec. It will auto format your new card.
R
rockyrr
Maryland
DR500GW-HD
I think what happens is once you insert a formatted SD card in your camera and then supply power (12V) it then automatically loads the software onto your card.
linni
Estonia
Upgraded to 64GB memory card, so far so good.
Pebo
North Fort Myers, FL
Blackvue DR500GW-HD, DR550GW-2CH and 2- DR650GW-2CH
If you format the SD card by using the camera, it will also add all the factory files to the disk.
Pebo
Interesting, and I'm excited to hear this. Has the recorder totally filled the disk? Have you tried formatting the card in the camera and then checking to see on your computer if the card was formatted to it's full (or nearly) capacity?
I hope it does work and if so, I'll upgrade also.
Thanks for taking the jump on this.
linni
Estonia
I formatted it in computer. First from exFAT to NTFS in Windows and then to FAT32 with Guiformat tool:
http://disk.yandex.com/public/?hash=DQ3 ... VARKCpQ%3D
At some stage it showed up like a 32GB card but no worry, Guiformat did the job.
Also be ready to use proper hardware - I used A-Data Expresscard cardreader.
And use the cluster size 32 kB (32768 B).
It shows free space something 59+ GB so I don`t see any reason Blackvue would behave differently than computer. Will give a look after a week - I usually drive only about 2 hours a day and it takes some time to fill the card.
Pebo
Thanks for the reply, I look forward to your follow-up to see if the BV uses the full disk.
Dscheng
Singapore
So does it really work on 64GB? Because 64GB class 10 microSD card is not cheap.
Mio
Ukraine
Xiaomi Mijia Car DVR & Xiaomi 70Mai
64 gb work without problems
Only need to format the device that supports this type of card
Do not format the DVR
Pebo
Glad to hear the 64GB worked.
To clarify your last post, are you saying to format the SD card using the computer and do not format it using the DVR?
themyst
New York
64GB formatted FAT32 with 12KB clusters will work just fine. The main limitation is 4GB max file size, but I doubt any video clip can approach that maximum single file size at even 3 minute clips at an insane bitrate.
