pmarstea
I know the Q800PRO allows setting up multiple hotspot. But it seems it only auto-connects to the last setup wifi.
Scenario:
1. Setup hotspot with car wifi (which is only enabled when car engine is on)
2. Setup hotspot with home wifi
3. Setup for parking mode
I would like the cam to switch to home wifi (if in reach) whenever the car wifi is off (always the case when parking mode is on).
Right now, if parking mode is on, wifi is not connected at all.
I also think that if I setup above steps in this order, the last hotspot setup (here: home wifi) is the one the cam will attempt to connect when car engine is turned on. Which is fine, if as soon as car leaves the home parking, it would switch to car wifi (it does not in my experience).
If I setup #2 before #1 above, then it will always connect to car wifi when available but will not fall back to home wifi, even if in reach. And again, if car engine is off, no wifi seems to connect.
Scenario:
