@EricSan thanks, great explanation, pics, and diagram! I thought you were running a dedicated battery
setup but I was not aware that it was something you built for performance.
I really don't think dropping the supply voltage by about 10% will change the current/power by any
more then the same ~10%. More of an academic question.
I don't have a place to put an additional battery source, and my truck spends about 85% of it's time
in my driveway, so I connected my HK6 right to the fuse box and mounted a little 2a "maintainer"
under the hood. I plug in the maintainer whenever I'm home, and my 3 cams stay in Low Bit Rate
parking mode with sound, indefinitely. Plus my main battery gets a little bump.
I'm retired and my trips away from home are close-by and short. I tested twice to see how long
my system would remain active with only the main battery and I got 8-10 hours... and the truck
started just fine at 12.1v or so. Not something I want to do regularly, hence the maintainer.
