I'm having trouble to establish the correct amperage output for a 12-5 volt hardware kit for my A119. I was intending to use a spare kit I had which was used to power a next base dash cam. This is a 12-5 volt kit with 2 amps output, but when I contacted Viofo I was advised to go for a 1 amp output only. The only other hardwire kits I have seen advertised for the A119 are 1.5 amp output which I also have but haven't fitted. So which hardwire kit should I use? A 12-5 volt kit with a 1 amp, 1.5 or possibly a 2 amp output? I should add I am going to use a piggy back/fuse tap to connect to a fusebox and was intending to connect it to the cigarette lighter 20 amp fuse and then add the dash cam fuse at the same amperage as for the hardwire kit ie either 2 amp, 1.5 amp or 1 amp.
