Yeah, they just probably forgot, I think they will correct that if they get the information, and can fix that in up coming batches.
Perhaps some other improvements as well, but I guess they will have to rely on user feedback for that. It is one thing to
get a product out there, and another to work out all the kinks or problems with the initial product.
Yes changing the way the GPS cable is connected to the mount is another thing they should fix. The way it is at the moment is just made to be ripped out sooner or later...
This is the one I used. Depending on the 0903 lens, it may or may not fit without a shim. If your lens sticks out a little you will need to make a shim.Hi,
Does anyone have a link to buy a CPL filter to fit the 0903? I don't really want to try to figure out how to magnetize shims and such.
This auction is cheap, but the seller says it will not work: https://www.ebay.com/itm/321978593915
Thanks!
thanks.. i'll just go for itThis is the one I used. Depending on the 0903 lens, it may or may not fit without a shim. If your lens sticks out a little you will need to make a shim.
