Custom firmware BlackVue DR550GW-2CH
alexsoll
Retailer
Minsk
Belarus
Street Guardian, BlackVue, Thinkware
Released custom firmware for BlackVue DR550GW-2CH
05.02.2015 - Released custom firmware 1.5
http://car-dvr.info/forum/index.php?topic=30.0
You can buy Blackvue here
http://car-dvr.info/forum/index.php?topic=584.0
https://dashcamtalk.com/forum/threads/custom-firmware-blackvue-dr550gw-2ch.4749/page-3#post-58193
yes
I imagine there will be a few happy DR550 users out there :D
Have you got a direct link to the English 550 thread alexsoll ?
we have a lot of money spent to achieve the result, therefore, priority right will be those who donated to the project customization
Sorry I'm slightly confused.... You want people to donate to look at an English thread on your forum?
I originally asked if you had a direct thread (In English) that folk here can look at. This would no doubt help you get more people using the custom firmware and potentially increase your "donations". If we have nothing to read then nobody will know about the firmware (unless they are Russian).
Original: http://yadi.sk/d/uQ4-7wNSLCVkb
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 76.1 MiB
Duration : 51s 395ms
Overall bit rate : 12.4 Mbps
Encoded date : UTC 2014-03-24 14:42:02
Tagged date : UTC 2014-03-24 14:42:02
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.2
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 50s 433ms
Source duration : 50s 467ms
Bit rate : 12.6 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 30.000 fps
Minimum frame rate : 29.412 fps
Maximum frame rate : 31.250 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.202
Stream size : 75.7 MiB (99%)
Source stream size : 75.7 MiB (99%)
Language : English
mdhd_Duration : 50433
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration_FirstFrame : 1s 987ms
Bit rate mode : Constant
Bit rate : 48.0 Kbps
Channel count : 2 channels
Channel positions : Front: L R
Sampling rate : 16.0 KHz
Compression mode : Lossy
Stream size : 290 KiB (0%)
Language : English
Would this be easily adaptable for the DR500GW?
alexsoll - is this custom firmware available or do you have to donate in order t get it. I just bought the DR550GW-2CH and i'm debating if I should cancel the order. My concern is the quality of the recording. and if this custom firmware fixed the issues then i'm interested. Your advice is appreciated.
original beta-custom firmware here http://dashcamtalk.com/forum/threads/custom-firmware-blackvue-dr550gw-2ch.4749/#post-56659
when the firmware is ready, I will notify users
http://car-dvr.info/forum/index.php?topic=221.0 - RUS
Thanks for the response. I wish I could read the language but I cant find a translator. Do you know the ETA for this custom firmware? I would love to donate but don't want to spend a year waiting for a custome firmware that will improve the quality.
thanks i'll give that a try.
I've visited and viewed the Custom Firmware thread. Question. Perhaps it is a translation to English issue, however, what is the "CERTAIN" amount $$ ???
Just trying to understand what expectations are.
Thanks
Nice that it is cracked, maybe Pittasoft will release regular firmware with it (if the cameras do not overheat).
I am wondering if they will release an updated version of the 550 ?? maybe the 570 ??
Also do we know if this new firmware makes the camera run any hotter ?
  • Like
Reactions: TEB
I believe the amount mentioned was around $10-$30
I'm willing to donate translation services LOL ... was holding off buying the 550 till the custom firmware gets sorted, but it has been a while, so unlikely to go for it now.
Thanks Dave,
So, if I might ask, what are you using?
