Cutoff Voltage Question
dan.dan
Ontario
I was told that if the Batteries Voltage right after the ignition is lower than the Configured CutOff Voltage, the Voltage Cut Off will not work.
For example, assume I set the configured cutoff voltage to be 12.3V. If the car battery voltage right after I turn off the car is 12.2V, the dash cam (parking mode) will remain ON and keep draining the power from the battery. I see this behavior in my F800 Pro dash cam.
Has other people encountered this issue too?
BlackboxMyCar
Retailer
Vancouver, BC
Thinkware, BlackVue, IROAD, Viofo, BlackSys
Shouldn't do that. Can you try a lower cutoff, such as 11.8V and see if that works?
Voltage detection may not be 100% accurate so the 0.1V difference for you may not be being sensed by the dash cam.
