There's some help for this
HERE and
HERE and
HERE
Essentially all RFI issues are the same, so the same solutions will apply with DAB. In short you want as much distance as possible between the cam and it's cabling, and the antenna and it's cabling. Snap-on ferrite chokes can help when used near the ends of cables (sometimes it takes more than one). Shielded cables or home-made shielding can also sometimes help. Try these solutions first before moving cams and cables.
No car or car audio manufacturer can design against every form of interference- the best they can do is test for problems with their own cars equipment or to follow good engineering practice regards shielding. Some cam manufacturers do better with shielding than others, but they too can't test their products with every possible car or installation. The problem comes from both ends and can usually be helped at least somewhat, but sometimes there's no easy solution and occasionally no solution at all.
It's a pain to undo an install, but that's what you have to do if added cable shielding and chokes don't get you acceptable results. Test the new cable routing by temporarily taping the cam cables as close as possible to where you want them to go, and do similar with the cam module. You car dealer may be helpful in telling you where the antenna and it's cable locations are so you can avoid their proximity. You may have no choice but to offset the cam to one side to avoid centered antennas, but at least you'll hopefully have both systems working that way.
Persistence and patience pays off here- rare are the cases where even a compromised solution couldn't be found. Sometimes a perfect solution can be found but don't expect that as that too doesn't often happen. All you can do is try different things till you get the best you can and hope that's enough. Good luck with this!
