Dash Cam doesnt record all the time.....
ultimica06
Hello!
Not sure if anyone else is suffering from this issue...
I recently noticed my Mini 0805 sometimes does record my entire roadtrip for some reason...I always check to see if the Blue Light is going and it is.
Also when I pop the Memory Card into my laptop for review the video files I notice there are files missing from a morning period video then skips most of my road trip and then the next file is a few hours later...which kinda sucks!..
There anything I can do to fix this?....or any hints??
Thanks!!!
tika67
Hungary
mini0805
Hello!
Thanks!!!
Hi!
I bought a 0805 two weeks ago, and I met the same issue. Although it seems like recording, but a lot of files are missing. Motion detection is off. Could you fix the problem?
jokiin
Too many ¯\_(ツ)_/¯
Hi!
what memory card are you using?
have you tested the card with h2testw?
tika67
Hungary
mini0805
One more issue. When looping, does it erase the whole card, and starts to rewrite it, or it starts to overwrite to oldest files? What I see it's a number of random files from different dates.
tika67
Hungary
mini0805
start by testing the card, the issue you have can easily be caused by a problem card, checking on the health of the card is always a good starting point
It's a brand new card, formatted by the dashcam...
jokiin
Too many ¯\_(ツ)_/¯
it's FIFO (first in, first out), the oldest file get's erased when the card is full to make room for the next file
yep, even brand new cards can be a problem
tika67
Hungary
mini0805
So, it wasn't this the cause. What else can be?
thancam
Retailer
Hà Nội
Viet Nam
too many
turn off G-sensor and try to use it again after format your memory card :)
tika67
Hungary
mini0805
G-sensor was off. In the first few days I looked at the recordings every day, trying to adjust the best setting. Once didn't want to record any more. I deleted all files, format the card again. This weekend I tested the loop, but as I wrote above, from 10 hours recording time, it just saved me 2,5 hours.
thancam
Retailer
Hà Nội
Viet Nam
too many
then try to power it from power hole in main body. Dont power it from GPS mount hole.
tika67
Hungary
mini0805
In this case GPS coordinates will not be recorded. The GPS will be without power supply.
thancam
Retailer
Hà Nội
Viet Nam
too many
that's your problem. The connection between main body and GPS mount is loosen. Recording all the time or record without GPS coordinates. You chose.
tika67
Hungary
mini0805
It's ridiculous to talk about things what we should not do. Turn off this, turn off that, don't use this, etc. All this stuff is a ****.
thancam
Retailer
Hà Nội
Viet Nam
too many
how's about warranty ?
