The seem to have a 2,5 inch AV-out connector.Most viofo models have AV out, latency is going to be around half a second on any camera though
check the cable, it does work but the connection is not a standard, you may find the video signal is not on the output your cable is wired toThe seem to have a 2,5 inch AV-out connector.
I bought the Street Guardian SG9665XS V2 hoping to use the AV-out, never managed to get any picture.
Hi,
Im looking for a dash cam that can give live output to a monitor with low latency, hdmi, analog, displayport or whatever.
Any recomendations?
I did try seraching the forum
How is the HDMI picture quality from the Mini 0805P?I have been using a Mini 0805P(I will double check)to stream to 6 monitors on my tour bus, using an HDMI cable. It has worked great for 2 years & the passengers love it. The only thing I'm not sure of, if the cam can record while streaming thru the HDMI. I also run a Vicovation Opia2 to record for my protection while driving....
