TakeMyCash
Hello. Is there a dashcam that has both front and rear (hard wired) where the front dashcam can be easily instantly removed without needing to unplug any wires (and then plug them back in later)? So essentially the power and rear connectors would go into the stand for the front camers instead of the main unit.
I am aware that the Viofo A119 (and maybe A129) has the power going into the actual stand for the front camera so if you were to use the front only then the removal of the unit is instant as it snaps on/off, however adding the rear dash cam connects into the unit itself so requires unplugging of this wire first before you can remove the unit (as I understand it, could be wrong).
My main reason for wanting this is fear of someone breaking into the car to steal a dash cam, so am thinking if getting one I can quickly and conveniently remove everytime I park up.
