Dashcam installation
DocHudson
Hello folks,
I will set up dashcam today. I am wondering if I can stick the mount on black dots area of the windshield (not too sure what its called as). I can't use suction mount there as it doesn't work but sticky mount should work.
Thanks in advance
An adhesive mount should adhere to the dotted area with no problems.
Our GT680W came with sticky attachments. After a misplacement, I pealed off the provided adhesive and used 3M double sided sticky on the frit (black dots). I just got the car back from replacing the windshield and the bracket went with the old one. I asked to have it scrapped off and left in the console, but apparently the installer had the same success I did in removing it and likely broke it. The 3M sticky is available in black for a less noticeable install.
If its a glue on mount it will work just fine, if its a suction cup mount it might work.
In my little Suzuki car i have a suction cup mount on the dots and it have worked perfect for months, but same suction cup on the dots in my sisters Ford fiesta only work for 2 minutes.
