Dashcam Store Installation Kits
Auld Reekie
I'm considering purchasing a http://thedashcamstore.com/installation-kits/ from the dashcam store to hardwire my 0801. Reading the instructions seem straightforward enough ...I hope :)
As my current connection method of the charger in the cigarette lighter/aux port is permanently live I want to have the camera switch on/off when I turn the key in the ignition.
At the fusebox is it just simply a case of adding the add-a-fuse circuit to any fuseboard slot which is only live when ignition is on for example electric windows/rear screen wiper which only work when ignition is on.
Car is 02 Ford Focus 1.8 tddi (uk model)
hpad06
too expensive, similar things together can be bought for around $10 USD
tweety889
Singapore
Mini 0805, B40S, DOD F500
or you could just get a regular cig lighter adaptor with a push on/off button.
CheckYourLights
Front&Rear-SH800/ Front 2nd Vico-Opia 2
Walmart sells a three way split with a button that I use in my car when testing more then one camera at a time.
