jno
- Jan 11, 2016
- Region #77
- Russian Federation
- TrendVision TDR-718GP
It looks quite common worldwide
The author of Registrator Viewer was killed in a motorcycle accident last year , so no further development is likely to happen.
altitude was never supported in all models with Registrator Viewer, the Mac version is done by a different developer so may get further updates still
some of the Ambarella cameras support it, basically the full functionality of the program is for Datakam cameras, others that use the same hardware as Datakam use benefit from that association
HI,
OK, thanks, I understand.
Hi,
I am back again and sorry for being a PITA
Having taken a closer look at RegistratorViewer I found out " Altitude " is supported in v 6.0.0.8 to so need to improve anything at least for the moment
even though the software supports it you will find it's still only for some models of camera that it works
Hi,
The Transcend DrivePro 220 is not listed in the huge list of supported cameras, but RegistratorViewer does perfectly read the Video files as well as the *.nmea files.
Great
Please, discuss all bugs and suggestions with Andrey in this thread.
Yes press Ctrl key as you click the program and select Open. Then you will be able to launch it.Is there any bypass available ?
I have exactly the same situation.Got a problem using Datakam on my MacBook Pro. Managed to play a video from my NextBase Duo with Datakam just once, the first time I ran it. Now it just doesn't play. I load Datakam; the screen shows black. I try to open a file but no response from the program. I've uninstalled/re-installed but no luck in getting it to work. Any suggestions?
I have a Grdian defender, nice little Cam, but the GPS into is in log files separate from the video. There is lat/long/speed info on the video screen. How do I use the GPS info to show location on the map window?
Datakam released Player Mac.
Users like Datakam Player for Windows (also known as RegistratorViewer). So we decided to create the same application for Mac. Result of our work you could see on the screenshot below.
Of course there are lot of things to work on. But at the moment Datakam Player supports dash cams from: Mini, BlackVue and Datakam; it allows to cut video fragments from one file or file group.
Download link is here.
You are welcome to make feature requests and submit bug reports.
Datakam Player 2.0 released. Now it allows to cut video fragments from video file or video file list.
