Thanks for your feedback and suggestion.
Currently, we are working on new firmware for A119 V3, A129 Duo and A129 Pro. These 3 cameras can support 512GB card in theory.
But big capacity memory cards can cause unexpected issues especially if using parking mode a lot.
Plan to support exFat format on A129 series, and optimize parking recording to improve the stability. Soon we will offer beta firmware for testing.
We need more time for testing new firmware due to some models updated to the latest SDK, and new features added like supported Wi-Fi Station mode on A129.
For write logs to the SD card, before we offered some debug firmware for some users to test, it doesn't help too much for debug.
And if write logs in the SD card, it may cause the unknown issue, it also takes chipset resource.
To VIOFO: I really like my VIOFO Dual 4k camera.
Interesting issue on G-force setting. Normally, I ran G-force setting to max and same with park mode. While on a long trip, I got the triangle message when I hit a bump, but felt it was valid.
So, I decrease it to Medium and work okay, no messages. After a period of time, I got triangle message, but didn't think it was valid. Didn't feel a bump.
So, I decided to put the G force to low. A week goes by and on a longer trip. I was getting 4 or 5 triangle message but felt it wasn't valid, as I hit harder bumps and rolls before on high sensitivity. Even watching those clips, indicates no bump or rolls.
Next day in the morning -8 C, left it the same and travelling through rough construction roads, no issues, no messages. Cabin temperature was normal. On a return trip, taking the highway, mostly smooth, I started to get Triangle messages, about 3 or so on 10 minutes drive, before I arrived at my destination. None of the triangle message was valid.
I notice a pattern. My unit was a bit warmer to the touch, but not hot, then normal, more likely to happen on a long ride. Seems like the problem appear when unit get a bit warmer than normal
I don't know what method is used to determine a bump on your device, but it gives the impression that temperature of the unit is changing the value of the sensor for G-force. Could be a software bug, or needs to compensate for component temperature changes? Any ideas on possible cause?
I don't expect my Park mode sensor would have an effect. So didn't touch it, as park mode is the most important for me.
Not an issue, just a minor thing so far. I can turn it off if needed it. With 256gb storage, I would catch the event, as long as i take it with me.
Sideline:
For the fun it, I tried the wifi connection to my iPhone, setup my iPhone to capture my screen in video. Camera was recording and streaming to my phone, which I was able to view and it capture and saved the video to my photo app.
Nice..... though it didn't capture in 4k, it capture on my screen resolution in H264 which played with no hesitation at home with apple photo. Found that interesting, when I did use H264 initially, playback on apple photo was with hestiation, but switching to H265 ran smoothly. Must be an implementation of H264 on the VIOFO camera??
The VIOFO would need to support 4k saving to the phone. Might make 1TB iphone and apple icloud interesting....
I love the reliable WIFI connection, it works great, unlike the others I have tested, which I was quick to return.
Keep up the good work
Aly
