Damn Dirty Ape
I'm working with a DC cam with no rear cam installed at the moment, firmware 1.32(b).
I have the 3-wire installed and it does switch to parking mode correctly and comes out of it as well. I'm using the supplied 128gb memory card as well.
i understand that holding the power button for 5 seconds should initiate shutdown on this camera; randomly it will not. sometimes on release of the power button after holding for the length of time it will not shut down but the REC button will stop flashing and the camera locks. No more flashing, just a live pictures on the screen but none of the menu buttons will respond. It will release itself from the lock after random periods of time, switching car on or off to set/cancel parking mode works either.
That being said - sometimes under the same situations the power button will initiate shutdown as it should - but not as often as a no resonse/lockup to the power button being used.
It's in the 70's right now and cloudy; camera is not hot and this offucrs regardless of the temperature.
Thoughts or suggestions on where to start first?
