winter4w
- Jun 12, 2014
- G1WH
GPS mount?
Yes, I have my timezone set so the GPS auto sets the time. If unplugged for a few hours the time resets back to 01/01/2018 until the GPS reupdates it.
I would start from the beginning with the installation, and then carefully documenting every step, every system affected until the problem is identified. Based on our experience it is highly unlikely that the hardwire kit is at fault.
I have reported just about every step I took along with screenshots. I did think it was a grounding issue at first but after testing multiple ground points and putting the HW kit on those points I have had the same issue.
for anyone that has had an issue we've replaced the hardwire kit anyway just in case, to date we've only had one that was confirmed to be faulty
If someone has a 800cca battery, cca is cold cranking amps. (To start the engine) Primary function Question of that battery would be how much power is available for a short burst, not how much standby capacity it has. If a dashcam was cutting off at some shorter period say under an hour or so you might think it's a hardware problem, computer controlled circuit etc but that is unlikely when it's going 4 to 5 hours each time. Many people think car batteries are huge so they have massive potential, but it doesn't work like that unfortunately.
Here is the battery I have in my car https://costco.interstatebatteries....26&choice4=1207627&choice5=1207628&Country=US
