DDPAI Z50 Pro (unboxing & impressions) (GalaxyCore GC8613 / SmartSens SC223A, HiSilicon, Wi-Fi 6/GPS, 4K front/1080p rear)
Augustus
Perth, Australia
Viofo, Vantrue, 70mai, Wolfbox, DDPAI
After previously reviewing DDPAI's current flagship offering, the Z90 Master, we return again with the Z50 Pro. This is DDPAI playing at the low-end of the dashcam market, which has quickly moved to having true 4K solutions. The front sensor is a GalaxyCore GC8613 4K sensor, with the rear incorporating a 1080p rear sensor (SmartSens SC223A). Therefore in full two-channel config we have 4K30fps front and 1080p25fps for the rear camera (with accompanying apertures respectively of F1.8 and F2.0 respectively). The fields of view are 143 degrees for the front camera, and 124 for the rear. The physical dimensions are 36.8x64.7x83mm, and there is no battery on board, only a supercapacitor. The DDPAI Z50 Pro tips the scales at 187 grams.
In terms of storage, the Z50 Pro works with the solitary option of memory card storage, expanding this by up to 512GB using microSD.
Turning to the box contents, we have the essential contents on offer. There is a two-tone affair with white text imprinted on the black/dark-gold packaging. There is a single box which contains instructions, an electrostatic sticker, and spare adhesives. Coming to the dashcams themselves, we have the main camera itself (DZ2509), with the rear sensor camera nestled underneath (RC3), separate power cables for the front and rear sensors, and the 12V cigarette lighter adapter. There is no CPL filter but there is a pry tool included in the package. Note that for the cigarette lighter adapter, there is a spare USB-A port on offer - both ports are unmarked.
First impressions of the Z50 Pro are positive. We have a nice matte finish with the DDPAI logo and the surrounding enclosure. There is a 3-inch IPS display on the main unit (with a resolution of 640x360), and four physical buttons underneath. There are also multiple ventilation holes on both the main camera unit but not the rear camera unit.
Installation of the Z50 Pro came off without a hitch. There is the offer of integration with their B13 4G Cloud Box kit and OBD2 kits. Contained within the packaging for this kit are spare 3M adhesive and SIM-ejection tool.
Included firmware version from the factory was V8.0.0.17 with no build date specified.
Would like to extend my gratitude to DDPAI for giving me the opportunity to road-test their low-end 4K dashcam competitor of 2026. Stay tuned for my findings and review, coming soon here on DashCamTalk.
Some-close up photos of the DDPAI Z50 Pro dashcam:
Power Consumption, microSD memory card testing and Day One firmware update for the DDPAI Z50 Pro:
The DDPAI Z50 Pro uses their own DC205 cigarette lighter power adapter, which has been used on other previous DDPAI models. Power consumption in two-channel config (4K front and 1080p rear camera) hovers around the ~ 4.6W mark, with operating temperatures being quite reasonable too at around ~ 26 degrees Celsius.
When testing the DDPAI-branded microSD memory card, which can write and read at very respectable speeds of 98MB/s and 93MB/s. The maximum microSD memory card support for the DDPAI Z50 Pro is 512GB, which is in deficiency to some of it's competitors which offer support of up to 1TB capacity microSD cards. Also handily there is a built-in memory card speed testing function within the system menu on-board the Z50 Pro, in which it will happily ascertain whether a memory card is high-speed or not.
Upon connecting the DDPAI Z50 Pro to the DDPAI Android APP, I was promoted for a firmware update to V8.0.0.17. Changelog states: fix common issues. The firmware update process was painless, and the most detailed I've come across from any dashcam vendor to date. An audio prompt was also played: "the firmware upgrade of the dashcam is complete".
Much like has been the case with other DDPAI products in the past, I would expect a raft of firmware updates in the coming months to smooth out, and add some exciting new features to the Z50 Pro, and to squash bugs and refine the dashcam & 4G user experience.
Bitrate Values, Wi-Fi transfer speeds and Resolution Settings for the DDPAI Z50 Pro:
Front camera (recorded in 2160p HEVC 30fps): 33.6 Mb/s
Rear camera (recorded in 1080p HEVC 25fps): 8.4 Mb/s
(all recorded in two-channel configuration at maximum resolution settings)
Audio: AAC format recorded at 63kb/s at 16kHz resolution
Wi-Fi transfer speeds (using WiFi 6): 6.65MB/s, where file size for one-minute 4K clip is ~253MB
It must be noted that even though WiFi 6 is advertised, there may only be support for 2.4GHz band only - this is why transfer speeds are of such low value, and there are also no user settings within the app or dashcam itself for 2.4/5GHz selection.
Video resolution settings
: Front camera: 4K anti-backlight @30fps, 4K anti-flicker @25fps, 4KSD @25fps
Rear camera: not configurable but records at 1080p @25fps
The DDPAI Z50 Pro also has a nice watermark that appears when you are recording a video in 4K resolution, denoted by the 4K logo next to the DDPAI logo below. Also for the first time that I have seen on any dashcam from any manufacturer, a logo denoting that the rear channel is being recorded with that video instance.
Screenshot_2026-09-23-14-56-33-514_net.mediaarea.mediainfo.webp IMG_20260923_145651.webp Screenshot_2026-09-23-14-31-22-856_com.cam.ddpai_overseas.webp
OBD Intelligent Hardwire Kit Experience for the DDPAI Z50 Pro and integration with 4G Cloud Box:
Contained below is the a curation of screens for getting the DDPAI Z50 Pro to work with DDPAI's own DC003 OBD hardwire kit, with seamless integration with DDPAI's 4G Cloud Box (B13). Quite the painless setup, which is concluded with the direction to download the APP from the users relevant APP Store.
In stark opposition to the Z90 Master, the Z50 Pro is a relatively straightforward affair after reading the paper documentation contained within the DC003 retail contents. This is demonstrated in the photo below, of how the physical layout should look.
Upon installation of the microSIM card within the B13 4G Cloud Box (and powering on the vehicle), the green indicator light on the Cloud Box blinks continuously. There are options to perform self-diagnosis of the 4G experience, as shown in the screenshots below. Also available are paid options to subscribe to 30-day, 180-day, 365-day and 730-day data plans from DDPAI. I believe users also have the option of using their own network-provided SIM cards, in case they do not want to pay DDPAI's subscription plan costs.
1791117392567.webp 1791117392617.webp Screenshot_2026-10-04-17-32-39-555_com.cam.ddpai_overseas.webp Screenshot_2026-10-04-17-15-40-602_com.cam.ddpai_overseas.webp Screenshot_2026-10-04-17-15-17-596_com.cam.ddpai_overseas.webp IMG_20261004_193223.webp IMG_20261004_193350.webp
4G Cloud Box experience and settings with the DDPAI Z50 Pro:
Once up and running, the 4G Cloud Box B13 experience is pretty seamless. There area number of options available within the DDPAI APP, namely Live View, vehicle location, cloud album access, geofencing (what DDPAI calls Electric Fence), and push-to-talk. DDPAI has the most settings I have seen in a 4G experience from any vendor to date.
Upon checking the Live View, there is an overlay with the amount of data that has been consumed, along with the current data transmission rate. There is also the option to choose what bitrate you wish to stream video from your monitored parked vehicle in. These recorded cloud videos are also available to be downloaded there and then, at a resolution of 720p, and at a maximum bitrate of 1.5MB/s. Options are present to capture a screenshot of the current live-streamed video, capture video of the live-streamed event, or push-to-talk to talk through the in-built dashcam speaker to any occupants within the vehicle.
There are also a couple of options present in terms of parking monitoring, whether that be time-lapse video or emergency event detection parking mode. Users can also set the voltage cut-off value, so as to not drain the vehicle battery.
Screenshot_2026-10-04-17-20-56-414_com.cam.ddpai_overseas.webp Screenshot_2026-10-04-17-23-40-108_com.cam.ddpai_overseas.webp IMG_20261004_193243.webp Screenshot_2026-10-04-17-26-21-078_com.cam.ddpai_overseas.webp Screenshot_2026-10-04-17-27-31-496_com.cam.ddpai_overseas.webp Screenshot_2026-10-04-17-27-39-260_com.cam.ddpai_overseas.webp Screenshot_2026-10-04-17-27-44-929_com.cam.ddpai_overseas.webp
