Disable G sensor on C-100?
THP165
Brazil
Hello,
Does anyone know how to disable the G sensor on the Blacksys CF-100?
Even seting it up at the minimum trough the PCviewer (scale 1), it still register "shocks" for every street imperfection, and even strong acceleration of my car, so I guess the only way not to let it full up my SD card is to disable it...
Do you have any tip on how I can do it?
Thanks for help!!
Can't be turned off, sadly. I found mounting the camera with dual lock rather than the supplied sticky pad reduced the amount of files the G-sensor locked. It also helps if you ever want to take the camera down for whatever reason.
The stronger the dual lock you can find (more stems per inch) the better it will hold. The stuff I used was the weaker variety I suspect (Command damage free hanging strips, designed for hanging pictures up on walls) but held well enough if left alone.
So, lesson learned, I won't buy another camera that has a G-sensor that can't be turned off completely.
Thanks for your answer, I had also contacted Blacksys who, by the way, never answered...
No problem, I also tried contacting Blacksys once but never got a response either.
