rsmck
- Oct 14, 2014
- United Kingdom
- Mobius, Transcend DP200, K1S
Originally I was going to use the Mobius as various installation techniques are well documented but we have a Transcend DP200 in our other car and I love the WiFi feature to be able to grab clips off the camera without removing the SD card so I set about trying to install it in our BMW 520d...
Problem #1 the BMW has a camera cluster of it's own directly behind the rear view mirror. This seems to be common with many modern cars with 'camera-assisted systems' e.g. adaptive lighting, lane departure warning etc. Therefore when the DP200 was mounted to the side of this, the housing of the OEM camera obstructed much of the right hand side of the image.
Problem #2 BMW for some reason saw fit to put the fuse box in the boot... as opposed to our other car (Seat) which has it easily behind a removable panel on the end of the dashboard.
Problem #3 (well, not really a problem, but just a personal opinion) I don't like the look of the DP200 - the huge silver ring is really prominent and might as well advertise "steal me" if it's permanently glued to the windscreen. The other one we have is sprayed black
Determined there must be another way I dismantled the DP200 and quickly discovered you can extend the lens from the DP200 a short distance without issue in much the same way as you can with the Mobius.
The next pleasant surprise is there's a little empty space near the top in the plastic trim that hides the OEM camera which, coincidentally, is almost exactly the same height as the circuit board the DP200 camera sits on;
So, a couple of spare trim pieces later and some Sugru ...
Not quite as OEM looking as I'd hoped (the lens sticks out further than anticipated) but it's a good start. [EDIT: Later I modified this a bit, see below, the lens is now further back - still not perfect but an improvement]
At the moment there's still a few issues I need to sort out;
- My initial 'tap' for power from the rear view mirror connection has been unreliable, so I've removed it and it's plugged in to the lighter socket for now. [Resolved, See below]
- Also the 'dash cam power box' I had (was supplied with my Mobius) is horribly manufactured, and I'm just not 'happy' with it, so going to come up with a better solution for 5v power up there (which I'll post here when done). [Resolved, See below]
- I want the DP200 display, SD card and buttons to be accessible (you can actually fit it inside the back of the trim piece but that's not ideal and has potential heat issues) so need to fashion some sort of replacement flat / plain 'back casing' now that the lens isn't on it [Resolved, See below]
- I'm experiencing some interference with DAB which seems to be a common problem with the Transcend DP200 which is very disappointing (not least because even if they admit it's a fault and release a fix I've well and truly invalidated the warranty of this one ) - [Partially improved, see below]
