mister_rf
- Feb 24, 2013
- Bucharest
- Romania
- YI /GT300W / C1 / DIMIKA / E720 / MOBIUS / DVR207 / 808 # 18
As in general, I like this small camera, but I was disappointed by the fact the red LEDs light is transmitted trough a diffuse surface and those LEDs are not useful in daylight.
IMO they have spent too much in the blue LEDs ring's light, and those LEDs are useless in my opinion, but hey, luckily you may power off those LEDs by the remote control application.
So I have decided to do some minor modifications.
My first idea was to change those red LEDs with more efficient ones. Later on I have discovered that’s not so simple to change the LEDs mounted on the flexible cable, and maybe a better solution is to replace the old LEDs light guide with new optic cover lens for improved daylight visibility.
In order to change the LEDs back side optic cover, we need to dismount the case. That’s not so difficult to do; you need a sharp tool and some patience.
The replacements lens was a quick ghetto solution by cutting the top of some 3 mm LEDs, followed by small adjustments for the right height and diameter, and polishing the cutting area for enhanced optical efficiency.
For the top cover I didn’t use any glue, I just pressed the new lens in place, but for the backside a tiny drop of glue was added inside the case to block the new lens.
and the results are amazing
