Thanks Niko , for the advice and the heads up re the 60fps.
The Panorama 2 does not seem to come across too well on vid quality so I think I will go with your recommendation for the Lukas as it is also available from a local seller .
I disagree with you @
" ... The Panorama 2 does not seem to come across too well on vid quality " . You probably watched youtube videos. It's never recommended making a full judgement from youtube videos, - they are compressing files.
You have to download RAW video files to get real result.
The only way to say what is best and what is not, is make a side by side tests. Only then can tell.
From my experience and also following some major Korean forums, I can assume that Lukas-LK7900 will have same video quality as Panorama2.
Panorama2 has some other advantages over Lukas, as well as Lukas has some others over Panorama2, but by video quality day / night I would put them into same category.
On Lukas I like ability to use up to 128Gb memory card and now OBD module as well.
Also option of having a CPL filter.
Don't like: - it does not have a screen and it is much higher in price than Panorama2.
From point of view of video quality,- they should be equal. After that everybody can chose what other options / functions they are prioritising and of course having local Lukas dealer is a big advantage.Myself also buying ( if possible ) high-priced electronics locally in case of warranty issues.
So from the list of dash cams you have in your title ( dod, finevu, lukas ), I would also go with a Lukas.
If you go to your local dealer to buy it, please ask when OBD device will be available, because non of my Korean contacts has them yet.
