Hi all, Bought the Blackvue 650 2 ch a couple of weeks ago and had it installed by Autobarn with a Digital Lukas 350 voltage cut off unit. Reading posts on this site Im slowly starting to understand how the cam works and the settings that suits my driving / parking. I have the cutoff set at 12.3 volts. Ive pegged back the motion sensor to 5-10 like everyone else found it too sensitive recording trees moving. My question is when in parking mode once the cut-off is reached does the dash cam turn off or does it go into standby ? is it then suppose to wake up and record for short period if the g-sensor detects movement and then go back to sleep? and can the same be true if I have the Lukas 350 cut-off unit set to time like switch off after an hour .
Cheers...................
