DerrickDFromAsia
The mount of my dash camera fell off the windshield a couple of days ago and I had to stick it back hoping it won't fall off again. Does the mount of your dash cam fall off or does it stick very well?
Thank you. I'll try to clean the windshield to see if that helps with the issueIt is normal for suction cup mounts to fall off occasionally, often when the weather has a low pressure area overhead, or when you drive up a big hill.
Sticky pad mounts should not fall off, but can if you don't remove all grease from the glass before applying them, a tiny amount of detergent, then well rinsed and dried will ensure they work well.
