Hi all,
I thought I will be another buyer that is pleased with this dashcam but NO this is not the case.
I bought Dome G98C a few weeks ago as a replacement for my old G1W (Notavtek 96650), yet it is G98C the version without GPS because I don't need GPS.
I may say I'm very unsatisfied with the video quality both day and at night. My old G1W with Novatek chipset performs better. I'm really disappointed.
Somebody said that the best resolution for this cam is 1920 x 1080P(60fps), in my case 60 fps is really to much for my cam, the image is very blur. I'm using 2304 x 1296 more or less better, but not as expected.
Is it a genuine Ambarella A7LA70 Chip inside? I have doubts.
Firmware: G90-ZX-A770-1424-N7H
When the car rides on a bad surface the DVR makes an awquard sound, and the video image for milliseconds becomes unreadable.
The DVR came in a simple box, not like the one I saw from different buyers.
Original Video Day: https://drive.google.com/file/d/0B6IagJ6b0c0qQkhpRGdkMmw1TEk/view
Original Video Night: https://drive.google.com/file/d/0B6IagJ6b0c0qUEtJOGdmYWNDYmM/view
Code:
General
Complete name : D:\Dome\2015-09-17-14-03-59.MP4
Format : MPEG-4
Format profile : JVT
Codec ID : avc1
File size : 520 MiB
Duration : 3mn 56s
Overall bit rate mode : Variable
Overall bit rate : 18.4 Mbps
Encoded date : UTC 2015-09-17 14:03:59
Tagged date : UTC 2015-09-17 14:03:59
AMBA :
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L5.0
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 3mn 56s
Bit rate mode : Variable
Bit rate : 18.0 Mbps
Width : 2 304 pixels
Height : 1 296 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.201
Stream size : 506 MiB (97%)
Title : Ambarella AVC
Language : English
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 3mn 56s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 3.61 MiB (1%)
Title : Ambarella AAC
Language : English
Text
Format : Timed Text
Codec ID : text
Duration : 3mn 56s
Source duration : 3mn 56s
Source stream size : 72.1 KiB (0%)
Title : Ambarella EXT
Language : English
