DR400G HD II Won't Boot
jimmy818
Likes
1
#1
Recently upgraded (or tried) to upgrade my north american DR400G HD II to firmware v1.014 english (the one currently on the blackvue website), based on digging through the logs i think i'm upgrading from v1.010
i believe the upgrade was successful, there was a voice prompt that said upgrading, then another prompt that said unit was restarting, then it seems to be stuck in an infinite restart loop but never successfully boots up
here's a few things from the logs that might be telltale signs of what's wrong
[22:00:30][check_model_info:934]app_version:[1.014]
[22:00:30][check_model_info:938]app_model:[400GII]
[22:00:30][check_model_info:942]app_language:[English]
[22:00:30][check_model_info:949]cli_version:[2.032]
[22:00:30][check_model_info:953]cli_model:[400GII]
[22:00:30][check_model_info:957]cli_language:[English]
[22:00:30][check_model_info:964]cfg_version:[1.010]
[22:00:30][check_model_info:968]cfg_model:[400GII]
[22:00:30][check_model_info:972]/mnt/mmc/BlackVue/Config/version.bin read End
[15:00:31][read_rtc:367] 2013-04-01 22:00:31 (1364853631)--25200
[15:00:31]Current 1364828431(-25200), build 1364853481
[15:00:31][read_rtc:367] 2013-04-01 21:58:01 (1364853481)--25200
[14:58:01]#####[check_version:1022]firmware_version:1.014, FIRMWARE_VERSION:1.014
[14:58:01][check_version:1039] config.ini is 1.010...
[14:58:03][JC:pta_parameter_init:3481] overwrite set >>>> (time)
[14:58:09]Start_System
[14:58:29][watchdog_main:517]EOUT1-3
[14:58:29][watchdog_main:522]EOUT1-4
[14:58:29][watchdog_main:527]EOUT1-5
[14:58:29][watchdog_main:532]EOUT1-6
[14:58:29][watchdog_main:537]EOUT1-7
[14:58:29][watchdog_main:552]EOUT1-8
this repeats almost indefinitely , in the nandlog folder
[13:13:34][main:1748]SYSTEM Start!!!
[05:13:36]######## main application Starting ##########
[05:14:39][watchdog_main:619] watchdog END2...
i tried to put in a blank SD card for the unit to initialize it on its own
it did detect and initialize the card but then gets stuck again in a restart loop
where it will flash the different colors, then go to solid blue
doesn't do anything for a bit and then restarts again
this is what it says in my version.bin
[firmware]
version = 1.014
model = 400GII
language = English
[software]
version = 2.032
model = 400GII
language = English
[config]
version = 1.010
model = 400GII
not sure if it even matters but heres the config.ini
[Tab1]
TimeZone=181
ImageSetting=0
Brightness=2
NormalRecord=0
VoiceRecord=0
DateDisplay=0
SpeedUnit=2
NormalRecordTime=1
EventRecordTime=1
StorageSetting=0
StorageRate=0
AutoParking=0
FileFormat=0
PROFILETYPE=1
[Tab2]
NORMALSENSOR1=20
NORMALSENSOR2=30
NORMALSENSOR3=30
PARKINGSENSOR1=80
PARKINGSENSOR2=80
PARKINGSENSOR3=80
MOTIONSENSOR=40
[Tab3]
LED1=1
LED2=1
NORMALCOLOR=1
PARKINGCOLOR=1
STARTVOICE=1
NORMALSTARTVOICE=1
EVENTSTARTVOICE=0
CHANGERECORDMODEVOICE=1
PARKINGMODEVOICE=1
ENDVOICE=1
VOLUME=100
AVOUT=0
Likes
#2
Sorry for bumping an old post, but you (or anyone else) come to a solution for this problem? I've started experiencing this same issue just recently. Tried re-flashing the (latest) firmware and formatting the SD card, but I just get a blue LED light and nothing happens, no recording. When I insert a formatted SD card, the voice will prompt it's formatting the 'new' card and reboot. But again, it'll just have the blue LED and no recording. After a few minutes, it'll reboot itself (flashing green/red), then constant blue with no recording.
Similar threads
