DR550GW - Custom Firmware 1.2 - Date and Time Issue
Saj
Likes
13
Nelson, Lancashire
Blackvue DR550GW
#1
Hi guys, got my DR550 all set up and recording and with the custom firmware 1.2 thanks to car-dvr.info!
Only problem is the time and date stamped on the videos, is all wrong and cannot get my head around how to amend it.
See below my current setting, bear in mind I live in England, so would set it to Europe/London, but the time is still wrong, way out in fact:
Not sure what exactly I need to do to atleast the time and date right, any ideas?
It looks like the system date is used in the stamp?
Saj
Saj
Likes
13
Nelson, Lancashire
Blackvue DR550GW
#3
Yes I changed it to London and still it was wrong, but your instructions were perfect:
"Delete the contents of the system folder & the record folder.
In the custom fw interface set the Hardware time to GMT.
Then set the timezone to your local timezone (in the blackvue app)... then reboot the cam.
Then you'll need to wait for a GPS location to update it correctly."
Thanks !!!!
Likes
17
#5
sorry didn't mean to hijack. just a sort of thanks for posting that pic with the "Set HW Time"
because i don't have this option to set HW time on firmware 1.0. i was looking everywhere for this and now i know what it looks like. so thanks:)
i guess there is not another way to change the HW time on CFW 1.0
RacingSnake
Likes
41
errr, it's exactly the same on all versions!!
I had (perhaps incorrectly) made the assumption you knew that you need to access the custom firmware interface instead of using the app?? (it is in the instructions for the custom firmware).
So connect to your camera via wifi, and enter 192.168.8.1 in internet explorer - the set HW time is on the very front page once it has loaded.
Likes
17
#7
here i can not find the "set HW time"
even in settings menu
Maybe it is CFW 1.1 +
RacingSnake
Likes
41
If you read through the main custom firmware thread you'll see a section fairly early on with me complaining about the time settings :D
at that time I was on version 1 and the button was there. :eek:
edit, I must apologise, on reading through my old posts it seems I went straight to version 1.1.
So I assume thats where it must have appeared.
So... upgrade ;) lol
Likes
2
Thanks for this I'll have to give this a try. Didn't realize I could connect via browser but I do have a question can I do this on the standard firmwrae?
Likes
2
So I pulled the SD card from the unit today and viewed it on a PC using the blackview 2.22 sofware and confirmed I am using 2.001-550GW-E Frimware. I looked at the GPS (mapview) and it has me in the right location but the time/date is off. I have the timezone set to America/los angeles-pacific which is where I am located. In the config.ini the Timezone is set to 126. But the time is still incorrect.
Is 126 the correct value in the config?
Any Thoughts?
Likes
17
#14
How do we find out what number is for what time zone?
I'm in Sydney AustraliaAustralia
Likes
2
Any Thoughts?
Update. Firmware 2.002 seems to have fixed the date issue for me!!!!
Likes
2
Is it easy to open the case to change the battery? I'll have to Google that to see if it is something I can do.
Similar threads
