beom
Hello, I've recently ran into an issue in my HOA garage where the property manager keeps targeting to tow my cars! Therefore am in need of help for my set up.
For now it charges wonderfully, and have the parking mode run all night. However my biggest issue is..I work 7 days on and 7 days off. My 7 days on are covered as I drive, charge and parking mode till I go to and from home/work. On my 7 days off, I do not drive at all (literally no miles once it goes back in the garage) and therefore no charging occurs and is just pure parking mode is required for 7 days straight.
I want to replace the Neo after its use with a 12V power bank Li-Ion to lengthen parking mode. Since it is garaged in a temp controlled space I am not worried about this factor. I was wondering if this set up is done correctly: I have a portable battery (1) specified below. I want to connect the usb-A to the power bank with the other end being a DC 12V (2) to connect to the camera end. Is this correct? I will also be unplugging the back up camera as it will be against the wall/not required and reduce power usage. I am not looking to connect to fuse/battery of my car. Thanks in advance.
Setup:
-DR750W-2CH + 128 GB
-Cell Link Neo 6 charged via cigarette socket whilst driving
-(1) portable battery: 20,000mAh Output Type-C/DC: 5V-3A 9V-2A 12A-1.5A(MAX) / Output USB1: 5V-3A 9V-2A 12A-1.5A; USB2: 5V-3A(MAX)
-(2) Wiring: DC 5V to DC 12V USB Voltage Step Up Converter Cable, Power Supply Adapter Cable with DC Jack 3.5 x 1.35mm
Setup:
