Major-OCD
I’m having issues with my blackvue RD900S-2CH Running battery flat.
first they were fitted with a power magic EZ and they drained the battery in about 24 hours. Not completely flat but enough for a low battery warning from the car. The car is a 3 month old high spec car so I’d expect it to have a high capacity battery.
mot was then recommended that I have a blackvue B124-X to prevent draining the car battery. That was fitted and it didn’t work. The battery would be flat within 8 hours from a full charge. I contacted blackvue and they basically said it was faulty and told to return it to the seller (amazon uk) for a repair or replacement.
mat this point I was thinking maybe theB124-X just wasn’t up to the job. So I decided to go for a egen Cellink neo 9 due to it having a much higher capacity.
yet the issue remains. The neo 9 lasts longer but it still doesn’t last anywhere as long as it should! I’m now thinking that the dash cams are at fault. Out of the 3 battery’s they can’t all be faulty, so in my eyes it has to be the cameras.
I’ve spent a fortune on cameras to protect my vehicle but yet they are switched off at times wile it’s parked up. The time they are needed most!
can anybody shed any light on this issue or has anyone had the same problem with these dash cams?
Cheers
Cheers
