Nigel
- Jul 7, 2014
- Wales
- United Kingdom
- Gitup F1+G3ꞈꞈꞈꞈꞈ Viofo A229ꞈꞈꞈꞈꞈ Blueskysea B4K
They are more complicated than you would initially expect, for example they have timers to delay shutdown to avoid use of the central locking turning it off by temporarily reducing voltage while the motors operate.So what you are saying is that the hk3 did not cut off the power for you in parking mode when using 9v battery? You are confirming my suspicions about the design flaw with this. I'm not happy about this.
Im curious if the hardwire kit for street guardian works like this too. I bet both were never tested with initial voltages below the cutoff point.
So I'm not sure if there is actually a problem. If there is and the problem can be reliably replicated then it can be reported to Viofo and they will fix it. But although my 9V test is reliable, it is not a problem because it is not designed for use with 9V batteries.
I do think your problem is that your battery is not operating correctly, but it would be good to understand why the HK3 doesn't behave as desired in this circumstance.
