- Feb 6, 2016
- New England
- Viofo, GitUp
I did the test below exactly. Isn't this basically what your saying? If not, I can try another test.Did you try testing using the input voltage from the point it shut down and referencing ACC from that point? That's what I did on the two tests that never shut off. If it shut down at 12V, disconnected power and reconnect, reference ACC to that voltage then remove, then start decreasing input voltage. I didn't test it starting off with low voltage to see what it would do, I may try doing that today later on. I guess I could also start very low and go up in voltage to see at what point it starts passing voltage.
Set the power supply to 12.4v and set the hardwire kit to 12.2v, powered on and then disconnected the ACC so camera went into parking mode, set the supply voltage to 11.4v, camera turned off after 100 seconds
Left the input supply voltage at 11.4v and the hardwire kit at 12.2v cutoff, connected the ACC and the camera powered on and started recording, disconnected ACC and camera went into parking mode, 100 seconds later the camera powered off
