Elfaro
I picked up elsewhere this reply
'If you Dash Cam is hardwired into the car, you're on a Switch Live fuse. I'd recommend transferring the fuse to a Permanent Live, that way if you have Parking Mode turned on, the Camera's battery will not drain. Our Hard Wire kit has an in-built voltage cut-off, so that if you car's battery drops below a certain point, the Dash Cam will no longer receive power and will not drain the car's battery to a point where it wouldn't start.'
As far as I am aware my 622 has been wired to a permanent live. However on 2 occasions after 3-4 days I have returned to my car and have a flat car battery. I have overcome this by now turning the camera off manually. Is there a setting in the camera that either turns it off or goes into standby without draining the car battery.
In the menu I cant seem to find 'Parking Mode'
