Dumb question - is the plastic lens cover hard to take off?
chodthewacko
I haven't removed any sort of cover off my lens, and I read it has a plastic lens cover.
Is it a clear plastic film on the lens? If so, I can't seem to get it off?
or perhaps it's not on there at all? Is it that hard to take off?
I suspect it's not there, but my camera seems pretty blurry though.
- Frank
PedroN
Haarlem
Netherlands
Viofo A119S front, Mini 0806 back, Viofo A119 V3
It should be clearly visible if there is still a plastic cover, it has a little piece of plastic sticking out which you can use to remove it. On the other hand the plastic on the screen is a bitch to take off. You'll have to pull it with great force which is not easy because you have almost no grip on the little tab.
chodthewacko
chodthewacko
I guess I don't have it:
You can see someone removing it in this unboxing video:
HunkyWunky
- Frank
It is just a simple plastic film . It comes off so easily (mine just came off when I touch it)
I thought your cam is out of focus. I have just contact the seller in order to return mine , because of this issue.
Sunny
Colorado
More than I can review. ;)
unpaidbill Mini 0806 1
unpaidbill Mini 0806 3
D Mini 0806 4
Ray1968 Mini 0806 4
C Mini 0806 8
