Hi, was wondering whether anyone else has experienced the same problem as I have with the Thinkware F770 park mode setting. My front and rear dash cams were professionally hard-wired into a 1994 Toyota Hilux. The dash cams were specifically bought for park mode which I need to record for about 12 hours over night. I set the dash cam in the motion detect setting (64GB SD card) but found that it recorded so erratically maybe starting to record as soon as the ignition is switched off and then recording for a few hours before stopping. Or it might start recording several hours after the ignition has been switched off and then continue for a couple of hours or more. I returned the front dash cam to the supplier and received a new one two weeks ago. Same problem. I parked at 5.00pm last night and even though the voice recording said "parking recording will now start" after I switched the ignition off, the parking recording only started seven and half hours later! The installer checked the wiring yesterday and gave it the thumbs up. I have been informed that my battery is fine. Voltage cut-out is set at 11.8. I was wondering whether it was possible for two new dash cams to be lemons. Anyone else have this problem?
