Error When Using USBDirect
richardkhill
My 0806 suddenly stopped working, and is displaying just the Red LED. A quick search has suggested using USBDirect to reset the firmware.
Unfortunately, I keep getting a 'Fail' message & my cam is still un-responsive. Can anyone help?
Have you tried to hold power-on button for about 15-20sec ?
Yeah. The red LED just comes on or goes out. Nothing else happens.
Have you actually flashed the .elf file?
frazzeld - I went back and double checked everything and found the *.elf file, which installed successfully. However, when I rebooted the camera, I got the three chimes & splash screen but then the screen went blank and a loud static type noise came from the speaker. Then nothing.
I repeated the USBDirect install, but still got the same results. Is this now pointing to a hardware failure?
Now try install a firmware via the micro sd
Tried to install a firmware via the micro sd, but kept getting the same problem; splash screen, three chimes, then blank screen with static from the speaker & the unit completely un-responsive. I tried from both sd slots but the result was always the same. :(
please remove the microSD card before power on. seems a card crash.
"I got the three chimes & splash screen but then the screen went blank and a loud static type noise came from the speaker. Then nothing"
can I have more details? best to be a short video
