ChaseRMc
- Nov 23, 2016
I have two different scenarios where the recordings get marked as an event. One is when I start driving it doesn't seem to come out of parking mode fast enough and ends up marking the initial drive as an event. Is this normal or are there better settings to prevent from this happening.
The other scenario is that when I hit a reflector on the freeway or just a bigger bump on the road the recording gets marked as an event. I have a Mercedes AMG so the ride is more rough than a regular sedan. As a result I have turned the g-sensor setting in the normal drive down to 2 on the side to side and front and back and I have turn the up and down to 0. It has made it better but did I just turn off the sensing capability for the up and down g-sensor? Are there any recommended settings that help these situations or are the default settings the best and should I just deal with more event markings than normal?
I updated the firmware to the latest but it hasn't made a difference for these two issues. Thanks in advance.
