kleanphil
Hi , ive searched for this issue but couldn't find a thread on it . As the title says , could this just be some feedback through the speaker or something more sinister ? I'm getting a similar noise in my newer F800 Pro
I have my cams connected to Cellink , which I turn off when in the garage , I only hear it then when the cam turns off . other than that it seems fine , hopefully its just static through the speaker , I cant imagine anything else making that noise without the cam being stuffed .Personally i have never had any reports of Crackling / Crunching sounds. If you listen very closely you may hear a slight static noise / click when they switch to parking mode etc and that is normal. You almost need 'Supermans' hearing to hear it though!
Hi , to be clear I don't use the on/off button on the cam , I switch off the Cellink and allow it to shut down that way and to save power in the Cellink , maybe that could be causing the staticI also have my F770 connected via Cellink B battery and when the vehicle is on the driveway, I also turn the camera off via the right button which is a press & hold untill you hear a tune, and I've never heard any crackling noise during the turn off procedue.
Yes that makes sense and I have been aware that it could cause issues but I'm lazy , I have 2 f770 ( 4 way cams ) hooked up so it was easier to just turn off the Cellink rather than turn off 2 cams , i'll see if I can change my habit . I've done this for a few years now with no issue i've noticed but point taken
Hi , the reason I posted here was because I was selling it and was hoping to find a solution before it sold , it sold before I could test . If he returns it i'll test it then 😉Out of interest did this procedure cure your problem or do you still get a crackle noise when turning off.
