rdash
I posted earlier in the main Thinkware Forum when I saw the F800 would be in Best Buy in late July. I had been following it pretty closely since and it seems our local Best Buys got them a few days into August. I picked mine up yesterday and installed (w/ the hardwire kit) earlier today. This ongoing thread here (https://dashcamtalk.com/forum/threads/f800-installed.30199/) has a pretty good list of the issues. Just going to reiterate some of them in one spot and add a few others. Thanks to folks in that thread I actually figured out WTF is actually needed to get to the settings in the F800 App.
My first issue (sort of) is that I downloaded the previous Thinkware App that isn't called Thinkware Cloud (F800). This one takes advantage of the WiFi that gets enabled from the dashcam and does *not* require a hotspot. It will connect once after the camera boots and if you close it or lose connection after that -- you are done and have to restart the camera to get it back up. Live mode in the classic app works fine -- as do *most* options. However, when I went to actually configure parking mode the app will crash.. which kicks you into the cycle of having to restart the damn camera to get the app working again. There's also a configuration option to change the SSID for the camera & set a password. This doesn't seem to actually take... it saves, disconnects, but nothing changes on the camera. Lame.
So then I realize this is not actually the right app.. even though some stuff works and there's setting you can't get to on the F800 specific app. So.. cue using the F800 app. It connects initially through WiFi relatively easily. But then it wants you to go to this horse**** Hotspot setup. I just escaped out at this point not realizing this is mandatory to configure the F'ing dashcam. What an absolutely abomination of a design feature. In any event -- once you exit out of the Hotspot config while on WiFi ... you can actually view Live Mode, access the camera's support and firmware settings, etc. So ... it appears you are connected to the camera just fine. WTF can't you make modifications to the settings at this point? Completely stupid design is clearly why.
Fortunately, I actually have the hotspot feature on my phone. I guess I would be S.O.L. if I didn't? Ridiculous. So once the dashcam is connected via hotspot you can access the settings. Only there's no setting to set a password or rename your Thinkware SSID. I guess that means if I have WiFi on and anyone nearby while my car is on can just connect to my camera, turn on a hotspot, and delete my videos/change my settings if they want? Seems super insecure and stupid.
There's also an option via "Support" which is available via both WiFi and Hotspot/Internet that showed Download Firmware. I downloaded it in WiFi mode. It doesn't tell you what the version is or tell you how to apply it. Trying to redownload will just inform you that it's already downloaded and will be installed when you launch the app. Uhh.. ok? It also shows the download as beeing 113,000KB ... which is around 113MB. Given it took like 3 seconds to download over my spotty Verizon connection.. I am going to guess they actually mean 113,000 bytes (or 113KB) and not 113MB.
Paint me extremely disappointed at the interface requiring a hotspot to do anything meaningful. Some of the features work fine over wifi with the old app though.. further proving this hotspot garbage is unnecessary. I'm debating if i want to ditch this thing or not at this point.
