skoubri
- Dec 24, 2014
- Greece
I've never seen a fake Mini0801 use a Ambarella A2 Chip The fake ones I have seen use a Novatek NT96220FGunfortunately after I bought I discovered the fake
You have to be very careful The 0801/0803/0805/0806 all use different firmware and using the wrong one will brick the camera.NONE of the firmwares around will work...
The 0803/0805/0806 use the filename firmware.bin the 0801 depending on where it came from might only work with the namesAs for the firmware after many research I think that this model will accept "firmware.bin"
I've tried to apply different firmwares for 0801 from this site and even wanted to try DirectUSB, but nothing shows up when I connect it with proper soldered cable to the computer. So my cam doesn't want to eat any firmware and doesn't allow to use Direct USB. Or I am complete noobThe likelihood of the original 0801 firmware running on yours is slim to none, there's a lot more to the camera than just the processor it uses
Link to listing bought from?Was bought on eBay.
sure,Link to listing bought from?
sure,
he shows the original one photos... but mine came as the photos I post..
to be so sure that it cannot run other firmware means that you have tried or you know something we don't... I could believe this only if the processor have some kind of locks or there is really different external hardware... but in these cameras the only external hardware is the RAM, the eEPROM and the image sensor...The process to put it into USB boot mode is likely different, once you did that you could extract the firmware, would likely never run a different firmware but if you could extract what you have you can do things like edit the boot logo, not really anything worthwhile in the scheme of things
Even that I haven't experience on A2 I think that the bootloader sequence is not possible to bypass from serial, so maybe you connect to the wrong UART or you have inverted rx,tx pins?I've tried to apply different firmwares for 0801 from this site and even wanted to try DirectUSB, but nothing shows up when I connect it with proper soldered cable to the computer. So my cam doesn't want to eat any firmware and doesn't allow to use Direct USB. Or I am complete noob. If someone is interested, I can do whatever you say with my cam, because I've got full refund and my 0805 has been ordered on gearbest. I'm new to dash cam firmware magic and maybe I'm doing something wrong.
https://www.ebay.com/itm/181524527774 this is where i got mine.Link to listing bought from?
R | Sent fake 0801 instead of 0803? | Mini 0801 | 8 | |
H | Is mine a fake? | Mini 0801 | 23 | |
Fake .. What to do ... | Mini 0801 | 17 | |
how to identify a fake Mini 0801 | Mini 0801 | 103 | |
(Fake 0801) $30-$44 USD? 1080P Novatek CPU 1.5" Car DVR Camera GS608 + 120 Wide Angle + G-senser | Mini 0801 | 75 |
