dg1972
So I got the U1000 without the rear camera.
1. I had a test drive yesterday, in extremely sunny weather. I had installed the CPL filter on the lens in the correct orientation. Everything was super over exposed. License plates were not readable unless you were right up on them. Otherwise, they were washed out in bright white. Is this normal? I left the brightness at Mid.
I switched the camera resolution from 4k/2k (front and back) to just front 4k. I'll see what that does today, but I expected better performance.
2. Does anyone have a program they recommend to consolidate the 1 minute files all together? Or am I going to be stuck using the old DOS command copy 1+2+3+4+5 = movie
3. I am using the OBD cable. I thought when the unit did not have parking mode enabled, and I turned off the car, the unit would shut itself down. This is not the case, I guess. I guess it might get a signal that the ignition was turned off, but it keeps recording full tilt until I power it off or yank the power cable. Once again, is this normal?
