2000rpm
- Apr 5, 2015
- United Kingdom
- Many, including JooVuu, Mobius, Street Guardian.
For some time I have been questioning whether many cams give the field of view claimed, or whether different manufacturers are confusing different terminology such as some reporting diagonal angle while others report horizontal angle and still others say one thing but probably mean the other.
So along with a bit of help from others I know with dash cams, and from examining comparison footage posted by reputable others, I approximated the relative field of view of about ten common or readily-available-in-the-UK cams.
The following table gives an idea of the relative field of view (rFOV) of the various cams looked at so far, rounded to the nearest 0.5 to keep things relatively simple. At the bottom of this post are two screenshots - one from a Cobra 840E (rFOV=5) and one from a Panorama (rFOV=10) and you'll see that the Cobra's field of view only sees around half as much as the Panorama, justifying the rFOV of 5 vs 10.
Cam..............................rFOV......claimed
Panorama.......................10.......135h/154d
A118/B40.......................9.5.........170
Blacksys CF-100.............9...........130d
SG9665GC......................9...........135d
Transcend DP200..........9............160
Transcend DP100...........8...........130
LS430W/ NB402G.........8...........140
Mio 528 / Mio538.........7.5..........130
Nextbase 101.................5.5...........120
Cobra 840E....................5.............118
Cobra 840E (720p60)...6.5..........118
h = horizontal angle, d = diagonal angle
And the conclusions?
My results - which admittedly could have errors and I am happy to re-evaluate if queried - suggest that some cams have fields of view that are wider or narrower than we're led to believe.
Even trying to explain away anomalies by noting that some manufacturers report horizontal angles while others report diagonal angles doesn't explain some of the anomalies.
So don't judge the field of view by the claimed angle because it doesn't always correlate with the actual field of view!
Some examples:
The claimed 170-degrees of the A118/B40 gave a narrower field of view than the claimed 154-degrees of the Panorama.
The claimed 160-degrees of the DP200 gave a narrower field of view than the claimed 154-degrees of the Panorama. In fact, the DP200 field of view was only slightly wider than the DP100, and looked closer to only a 10-degree difference despite the claimed 30-degree difference.
Interestingly, @jokiin's 9665 with a claimed 135-degree diagonal only had a slightly narrower field of view than the 170-degrees claimed for the A118C/B40, and was slightly wider than the mainstream cams claiming 130-140 degrees (Mio 5xx, DP100, LS430W, NB402G). It was, however, very similar to the Blacksys CF-100 which claims a similar angle.
The Cobra 840's field of view changes with resolution - oddly it is wider when on 720p than on 1080p (something I've commented on in the past) so clearly while it might give 118 degrees, it can't be giving the same angle on both resolutions.
Please note this topic isn't intended to be 100% accurate, but it is intended to get people thinking about - and questioning - their camera's or proposed purchase's claimed field of view.
Some examples:
