Nigel
- Jul 7, 2014
- Wales
- United Kingdom
- Gitup F1+G3ꞈꞈꞈꞈꞈ Viofo A229ꞈꞈꞈꞈꞈ Blueskysea B4K
I think there is some confusion about which direction is forwards, my camera is facing the front of the car, but the cabin image is facing the rear - that is what happens with dual lens cameras!In other words they are LESS THAN 90 degrees to the lens each, which is LESS THAN 180 degrees total. 180 degrees horizontal is a line connecting two points directly beside the cam left and right, with the lens of the cam being on that line between those points.
I never thought I'd have to explain 6th grade geometry here.
I still say that with a rear facing image, if the field of view was less than 180 degrees and the door mirrors were visible then you would see the plastic side of the door mirrors, while in my image above I see the plastic side of the rear view mirror but the reflective side of the door mirrors - the door mirrors are behind the view at around 200-210 degrees (100-105 degrees from the centre of the image).
