What's New:
Version 1.013:
Quick View Notifications:
When a Normal, Parking Mode or Manual Event occurs, a thumbnail is now displayed alongside the Push Notification sent.
Push Notifications are sent both when an Event starts (e.g. “Impact detected” notification) and when the recording ends (“Event recording saved”).
If you tap on the Push Notification, the app opens to display a popup with a large-size thumbnail and allow you to view a live stream (Event start notifications) or play a quick play version of the video (Event saved notifications).
Note: in case of quick play videos, only the front camera view is available. User can access the rear camera videos from the video file list.
Cloud FOTA (firmware upgrade via the Cloud):
Upgrade your dashcam’s firmware easily over the Cloud.
To use this feature, go to the BLACKVUE CLOUD menu in the BlackVue app (Cloud Viewer in the desktop application).
When a new firmware is available, an icon will show near your dashcam’s name.
Tap the 3-dot icon (⋮) > Remote firmware update > Update Now. The dashcam will start downloading the firmware and automatically apply it. You will be notified once the upgrade is successful or fails.
Write Error Detection:
Your BlackVue constantly checks that the microSD card is properly recording videos.
If your microSD card becomes write-protected (“bricked”), a “Check SD card” voice message will play from the dashcam.
What should you do if your dashcam prompts you to check the SD card?
First, try formatting the microSD card using the Format button on the side of the dashcam (Hold the button until a voice prompt plays, then hold again). If that does not fix the issue, try formatting using the BlackVue Viewer for Mac/Windows. Then if the issue persists, contact Support at cs@pittasoft.com.
Wi-Fi connection error voice prompt:
If you try to connect to the dashcam in direct Wi-Fi while another device is already connected, the following voice alert will play: “Direct Wi-Fi connection already in use”.
Version 1.013:
