I just upgraded my brand new LK-7950WD to firmware 19 (the only one offered) and now it only talks (voice) in Korean. Is that a known bug? How to fix?
You need to downgrade to FI17.
There is a bug, all users are offered to install FI19 which is Korean only at this time.
Format both memory cards just to be safe.
Just download FI17 from the link below,
Download Lukas LK-7950 Firmware Fi17 and follow these steps
- Download the firmware file from the link above and unzip the folder.
- Back up important data from your SD card and/or format your SD card.
- Drag the files located inside the unzipped folder to the SD card on your computer.
- Open the SD card on the Lukas Viewer and configure your desired settings and save.
- Eject the SD Card from your computer.
- Insert SD Card back into dash camera.
- Connect power then turn on the dash cam.
- Display LCD/LED should prompt a firmware update in process.
- After the firmware update is complete, the dash camera will automatically reboot.
- The update is now complete.
- Restart device manually.
http://lukasdirect.com/learn-explor...s-firmwares/84-lk-7950wd-normal-firmware-fi17 doesn't exist.That is a bug then.
Ill let the software team know.
You can download FI17 from the link below.
First I would suggest trying to format the memory cards, and set back to english. That might still do the trick. If down. Then downgrade.
Need latest firmware for lk7950 none OBD | LK-7950 | 7 | ||
I | Firmware 23/2.3, Korean language, WiFi issues | LK-7950 | 2 | |
B | Lukas-7950 (rear cam, no obd) will not update the firmware | LK-7950 | 0 | |
H | LK-7950 Firmware Upgrade Version Fi23 | LK-7950 | 14 | |
H | LK7950 Firmware Fi21 - Sd card error & Korean voice | LK-7950 | 22 |
