Firmware Auto-mode
rajoar
Spain
B1W
Well, I wanted to explain my experience with the software 20190114_blueskysea_auto-mode.
Both in mode with the car running, as in parking mode everything works correctly. Now, the problem starts when the 64GB card is full, because the led stays in permanent red and does nothing else. You have to empty the card so that it works correctly again. I do not know if I should configure some parameter that I do not know.
BlackRose67
Ottawa
Blueskysea B1W
Where did you get that firmware from? Is that the latest parking mode one from Vicky/estore009?
estore009
Retailer
Shenzhen
China
B1W/Mini0906
Where you got this 20190114 software? I suspend it is 20180614s firmware. You can get its version info in its APP menu after WiFi connected!
It might have some broken sections or invisible files in your card, so camera stop recording when detects the card errors!
R
rajoar
Spain
B1W
Yes.
The card is formatted with Guiformat, Fat32, Unit size 32768, Volume label DATA. I have reformatted it 2 or 3 times and the result is always the same: everything works until the card is full ... It does not overwrite data ...
R
rajoar
Spain
B1W
if you use a 32GB card does it overwrite correctly?
I do not have a 32GB card. I only have the 64GB, Intenso, class 10.
jokiin
China
Too many ¯\_(ツ)_/¯
I do not have a 32GB card. I only have the 64GB, class 10.
suggest trying a known good quality 32GB card, format in the camera, if it still has problems overwriting it's a camera issue, if it's fine then it's a card/formatting issue
R
rajoar
Spain
B1W
Ok!
estore009
Retailer
Shenzhen
China
B1W/Mini0906
I suspend that there was a warning "One MB missing" in your 64Gb card if you test it with T2testw tool
R
rajoar
Spain
B1W
Where do I download the T2testw tool?
SawMaster
SC
Mobius, G1W-S, G1W-HC,, G1W clone, B1W. VanTrue N2 Pro
Softpedia has it: LINK
R
rajoar
Spain
B1W
Sure enough, the 64 GB card had a problem. With a 32GB it works perfect. I could fix 64GB with a low level format and then formatting FAT32 with Fat32Formatter v.1.1. Thank you very much to all.(y)(y)(y)
J B1W 1
I B1W 8
T B1W 2
B B1W 10
D B1W 20
Similar threads
