My 750S-2CH was working with older FW 1.016 and updated it to FW 1.017. After rebooting, I can connect but when I select 'live', the default camera view (front), is only white screen and after a few seconds, the connection gets disconnected. The camera still power cycles with all the audio prompts.
These are the things that I had to fix it.
1. I tried reformating the sdcard using the camera button - did not work
2. reset the SSID pw - - did not work
3. used desktop software to format the sdcard - - did not work
4. used a working sdcard from my other camera (the same model) inserted it to the non-working dashcam - did not work
5. tried using the sdcard with another camera (the same model) - the sdcard works since the other camera works and records the video
Is there any other way that I can fix this or downgrade to the older FW?
Any feedback would be appreciated.
Thank you.
Thank you.
