Firmware updates
Sdeel7491
Is it possible to update firmware using an iPad, and if so how is it done in easy terms?
BCHobbyist
Vancouver
A129Duo-8WL A119Pro-9Tm A119S-6Vk A119V3 GitUp G3+F1 DCTeam
easiest and most reliable method is copy correctly named firmware binary file to main root folder of microSD card, use card reader with computer, insert memory card back into Dashcam then connect power cable and wait for it to restart 60-70 seconds.
If your iPad has card reader adapter to transfer files use that device, otherwise computer is best option.
S
Sdeel7491
Thanks I can't seem to get a card reader that works with my iPad! And I've only started on my iPad so I'm a bit green using a laptop! I would have a go if it was straight forward! I'm a bit long in the tooth I'm afraid!
S
Sdeel7491
You can also update through the Viofo app.
Yes thanks I'm using the App on my iPad but how do I update the card with out a card reader? I'm sorry but I'm not very tech minded a bit long in tooth as we say (old) .
CaptureYourAction
Retailer
New England
DOD, Dome Technologies, VicoVation, Viofo, GitUp
Connect the app to the A129. In the top left corner of the app, open the menu. Bottom option is FW Update. Not sure this can be done on an iPad though. Probably need to cell phone with WiFi and cell data on.
